waterwheelfarm
Apr 05, 2024Aspirant
Nighthawk M6 Pro MR6500 hot spot OEM power adapter
I purchased a refurbed unit through amazon and it did not come with a netgear power adapter & cord. I want to run this unit without the battery, but when I removed it, received the message: Use t...
- Apr 06, 2024
The one you found should work at 5V/3A/20W. The voltage is critical, but the amperage and wattage can be anything above what you stated. A 4-amp 30 or 40W adapter would be better. I don't have mine in front of me but when I get home, I'll see if it has a specific rating.
waterwheelfarm
Apr 06, 2024Aspirant
Well that's a shame. I wish they would at least confirm what I should get.
Does anyone know the correct volts/amps/watts I should use with this to run without the battery?
JT240Z
Apr 06, 2024Luminary
- JT240ZApr 06, 2024Luminary
Look for a USB-C power adapter that has a Qualcomm QC-2.0 or QC-3.0 quick charge chip in it. That should work.
- waterwheelfarmApr 06, 2024AspirantThank you for the help!
