Robboa's avatar
Robboa
Nighthawk M6 Pro MR6500 static client IP setup
Maybe I am going mad but I cant find where in the router to set a client device with a static IP tied to the client MAC address.  This is a fairly normal function of routers, so guessing it must be there, but I cant find it on the web interface or the devices touch screen.  Thanks in advance.
  • To set up a static client IP for the Nighthawk M6 Pro MR6500, access the router's admin panel through a web browser. Navigate to the network settings and assign a specific IP address to the desired client device, ensuring it falls within the router's subnet. Remember to save the changes. By the way, the 8 ball pool aim is not related to the IP setup process.
    • Robboa's avatar
      Robboa
      Unfortunately not that easy those options don't exist in the menu system I have looked as you say under settings... and everywhere else. The firmware is v1.0 and looks hastily built with spelling mistakes included like "didagnostics". If you have a screenshot from  the same firmware would be helpful?
      Fw:  NTGX65_10.01.38.00
      • iieeann's avatar
        iieeann
        Welcome to this expensive mobile router series without an extremely important feature.  This router does support Port Forwarding, but it does NOT have the feature to tie a device MAC address to an internal IP.  So the port forwarding will not work, how ridiculous.  This happened since M1 in 2017, and now is M6 pro and still going strong without this feature.
        That is the reason i did not buy this series mobile router after M1; and every new model coming out the first thing i do is to check if internal reserved IP feature is available or not.  6 years have passed and yet the answer is NO.
        There is a number of users asking about this feature in the community, and Netgear's reply is to talk to network provider to get a public IP bla bla... totally not understand the question we asked.  We only need internal IP reserved which has nothing to do with network provider.
