Lyricsf
Nov 20, 2023Aspirant
Nighthawk M6 Pro MR6500
I just purchased a Netgear Nighthawk M6 Pro MR6500 from Amazon. It worked great until I removed the battery for the AC power only In-Home Performance mode. After switching to the AC power mode, it at...
- Nov 20, 2023
More than likely an issue with the AC power adapter. It needs to be the original supply or, at least, a high-quality high wattage supply. Most hot spot devices sold on Amazon don't come with the right one.
JT240Z
Nov 20, 2023Luminary
- LyricsfNov 20, 2023Aspirant
Thank you for the reply. I haven’t found the compatible Netgear brand adapter/USB cable available for sale. I did find a 100W USB C charger with power delivery and USB cable on Amazon. A reviewer stated it works great with Nintendo Switch in docked mode. I think it is worth a try.
