Manitou
Feb 11, 2023Aspirant
Nighthawk M6 Pro no GPS setup
I have an M6 Pro in use (simlock free EU model). I don't see GPS setup in the menu settings?
Blanca_O
Feb 14, 2023NETGEAR Employee Retired
Hi Manitou
To enable GPS setup on the Nighthawk M6 Pro:
- Access M6 Web UI
- Go Settings > Advanced > GPS
Please provide the firmware version if you still cannot find it.
Blanca
Community Team
JohnPeng
Feb 15, 2023NETGEAR Expert
If you are using MR6450-100EUS, I don't think GPS is enabled on that SKU.
We are in the process to upgrade the UM to document the features clearly for all the SKUs.
Thanks
john
- ManitouFeb 15, 2023Aspirant
Thanks for your answer đ
My M6 Pro runs on firmware version : NTGX6510.04.25.00
GUI version : MR6500-GENERIC_05.00.68.00
