Manitou
Feb 11, 2023Aspirant
Nighthawk M6 Pro no GPS setup
I have an M6 Pro in use (simlock free EU model). I don't see GPS setup in the menu settings?
JohnPeng
Feb 15, 2023NETGEAR Expert
If you are using MR6450-100EUS, I don't think GPS is enabled on that SKU.
We are in the process to upgrade the UM to document the features clearly for all the SKUs.
Thanks
john
Manitou
Feb 15, 2023Aspirant
Thanks for your answer 👍
My M6 Pro runs on firmware version : NTGX6510.04.25.00
GUI version : MR6500-GENERIC_05.00.68.00
