mazar23
Nov 03, 2022Follower
Nighthawk M6 Pro Overheating Update
Hi everyone, Over a month ago I posted an issue I am having with the Nighthawk M6 pro overheating, freezing up, and stopping all internet connections. This is just an update I got from Netgear in th...
Harrydo60
Nov 17, 2023Initiate
I have this device always left battery in it heats up all the time now have to cool it off then reconnect to internet pain in the ( ! )
- little-endianNov 20, 2023Tutor
From what I observe with a M6 Pro using firmware NTGX65_12.01.48.00, the "overheating" issue despite Netgear's repeated announcements isn't fixed, at least not if a throttled performance when reaching a certain temperature threshold in order to prevent that very overheating falls into a similar category.
In my case, while the device itself continues to work without interruptions or restarts, the performance gets significantly degraded whenever the temperature rises above 62°C and the up- and downstream resources (3CA for LTE, 2CA for 5G) are more or less fully occupied, which with my current operator means about 32 Mbps upload and 320 Mbps download. Then, within minutes, the downstream droppes to 40-100 Mbps with higher latency times between 400-1000 ms. Cooling the device down by a fan reproducibly resolves the performance hit by significantly lowering the temperature (about 10°C less).
Whoever wondered how the heck a manufacturer wants to resolve a pretty clear hardware/implementation issue by pure magic of remote software (e.g. updating the firmware) might have an idea. He can't. Netgear's portable routers obviously lack the required hardware-based cooling and the very least they should provide is a heatsink one can attach inside of the freed-up battery slot when in stationary use. At least as of now, their devices are simply not suitable for power users and for the light ones, one can ask oneself whether a way cheaper pocket wifi doesn't suffice as well.
The heat issue for me comes to no surprise at all here - other manufacturers either use the mentioned heatsink in their devices or even add an additional fan to that, e.g.:
With Netgear's M-series though, consisting only of some simple plastic case around relatively high-performant chipsets, raises the rhetorical question where the heat should be conveyed that quickly - physics is greeting.
The temperature result in concrete is mostly made up of the following variables, taking the environment aside:
- chipset efficiency
- cooling/heat convey strategy
- programming code efficiency
- load
For the first two, it's already too late. The thing is built, packaged and shipped already. Only the second might be indeed an option if Netgear would deliver such a heatsink retroactively (with a more or less fiddly gel-pad included DIY-kit after one paid about 1000 bucks for that thing, hurray).
Third is possible, but not very likely to make a huge difference. Leaving number four, simply throttling the performance when this thing gets too hot. Which is exactly what happens.
Printing the return label ...
- sjbenderMar 03, 2024GuideI’ve noticed that the hotspot has become painfully slow after a firmware update that must have been pushed to the unit. (NTGX65_12.01.48.00) I typically do not update the firmware and was surprised this happened. My speeds are now 5 down, .06 up! Yes, .06… Is this a known issue with this firmware?
- IBN001Mar 15, 2024Initiate
Not the Pro, but bought the plain M6 through Telstra
Have had the M1, M2 which were fine and now the M6. What a disappointment. Should not be sold, especially for the asking price.
This is our only 'net connection due to our location. Just continual drop outs and connection refusals. Only solution is a reboot of the device. It is running without battery with the cover off. Firmware update request returns "up to date". Will have to look for an alternative solution.
No more Nighthawks for me.!!!
