mazar23
Nov 03, 2022Follower
Nighthawk M6 Pro Overheating Update
Hi everyone, Over a month ago I posted an issue I am having with the Nighthawk M6 pro overheating, freezing up, and stopping all internet connections. This is just an update I got from Netgear in th...
tumi4real2003
May 28, 2025Initiate
Heat sink - https://www.amazon.com/dp/B07JLQL63D?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3&th=1
Fan - https://www.amazon.com/dp/B07S51M3R5?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
You need to grind the heatsink so that you can still cover the back when not in use. You can cut the heatsink to fit the space with a Dremel tool
