bobupthecreek's avatar
Mar 05, 2024
Nighthawk M6 Pro SIGNAL STRENGTH through WALLS
Using Nighthawk M6 Pro to provide 2.4gz wifi network to operate three Wyze v3 cameras.  One camera is mounted outside on exterior wall.  This camera goes "offline" frequently, apparently due to unstable / weak wifi signal and must be power cycled each time to re-set.  How can I produce a stronger wifi signal from the NIghhawk that will pass through the exterior wall to the camera?
1 Reply
  • plemans's avatar
    do you have it set on performance mode?
    It could also be the exterior wall itself. Exterior walls tend to be made with materials that do a great job of blocking wifi.
    things like brick, foil lined insulation, cement board, metal siding, etc.
