jackings
Jan 13, 2025Aspirant
Nighthawk M6 Pro Slow Upload Speed
Hi there, I have a M6 Pro (EU version), connected to a high gain external antena. I can get pretty good Download speeds (200Mbps plus) but upload doesn't seem to get any better than 8 Mbps. I...
rcpax
Jan 16, 2025Luminary
Country? Carrier? APN settings? MR6450 bought new or refurbished/used?
jackings
Jan 19, 2025Aspirant
Country: Portugal
Yes, same SIM, same APN configuration in both tests (TP link mr550 vs M6 pro). M6 was bought new.
- rcpaxJan 19, 2025Luminary
jackings wrote:Country: Portugal
check with your portugal carrier if your m6 pro is a certified device to be used in their network, and explain your situation. bring the sim to your local carrier store and do a speed test so they see what you are talking about. from what you stated, everything you said is really all there is to do on the m6 pro. if you are not getting optimal performance, it could be a carrier issue.
