rloberto
Jul 19, 2022Guide
Nighthawk M6 Pro turns itself off a couple of times a day
I recently purchased an M6 PRO from Telstra to replace an AC800S that was an always-on service in our home. The AC800S battery swelled and exploded, nearly combusting in the process.... Luckily it dr...
JohnPeng
Nov 08, 2022NETGEAR Expert
jimsmithjojo wrote:
RIght out of the box this thing was garbage. The screen was somehow zoomed in on mine and I had to reset it just to power it on propoerly. The lcd screen is laggy as hell and is highly unresponsive most of the time.
Same issues that you guys have mentioned. I have had this M6 Pro for 3 days and I can't take it any longer. It just randomly shuts down, loses broadband connectivity, no internet. It will not save power settings either. Every time the device reboots the screen timeout resets to 1min. Ethernet port is terrible. Sometimes it's enabled, sometimes it's not. It only works half the time and then just stops working. I have 5 bars of service in my area and it keeps rebooting losing connection to the tower.
I thought that I might have purchased a bad unit... but sounds like you have the same issues. I am on the latest firmware. (unit updated the F/w automatically. was worse after the update).
Please check and make sure the device has been upgraded to the latest release.
Could you please advise your device SKU?
Thanks
jimsmithjojo
Nov 14, 2022Tutor
SKU: 6238D
Yes. it has been updated to the latest firmware.
