rloberto
Jul 19, 2022Guide
Nighthawk M6 Pro turns itself off a couple of times a day
I recently purchased an M6 PRO from Telstra to replace an AC800S that was an always-on service in our home. The AC800S battery swelled and exploded, nearly combusting in the process.... Luckily it dr...
Tarek133
Feb 26, 2023Aspirant
I have that issue with my M6 Pro, and firmware update hasn’t solved the issue. When I contacted netgear, they asked me to send it back & they sent a replacement. The replacement also had the same issue. I wonder if a fix to that problem is found. Coz that device should be the Rolls Royce of hotspots considering its price tag, but unfortunately it isn’t. I mean it gives impressive speeds, until it decides to turn itself off and everything goes down. And the only way to power it back on is to either remove the battery if you’re using it with the battery or to plug it off from power if you’re using it in AC mode…
