rloberto
Jul 19, 2022Guide
Nighthawk M6 Pro turns itself off a couple of times a day
I recently purchased an M6 PRO from Telstra to replace an AC800S that was an always-on service in our home. The AC800S battery swelled and exploded, nearly combusting in the process.... Luckily it dr...
robadams321
Feb 26, 2023Guide
The firmware update fixed mine. It no longer shuts off. Make sure the new FW version is 10.04.22.00.
Good luck!
Good luck!
M6issues
Apr 08, 2023Aspirant
Telstra purchased M6 Pro (MR6500) here. Dropping the Internet randomly and only get it back after a reboot or by making a config change. This unit is built into my 4WD and should be set and forget.
Went back to the Telstra shop, got a replacement unit doing exactly the same!
The 10.04.22.00 FW is not available for this unit?
For such an expensive unit I would have expected better!
When will the new FW be available in Australia?
