Needlenurse
Aug 22, 2024Initiate
Nighthawk M6 Pro use iPhone as a data source?
Is it possible to connect my iPhone directly to a Nighthawk M6 pro hotspot device so that I can use my unlimited mobile data for my desktop without an additional sim? My Windows desktop computer does ...
Needlenurse
Aug 23, 2024Initiate
I can only connect to internet via LAN on my desktop. WiFi not an option. USB does not appear to be an option. Nighthawk M6 pro is model MR6500.
Aug 23, 2024Guru - Experienced User
If you have a desktop PC, one could install a WiFi PCI or PCIe adapter card in the PC and then you can connect the Desktop to the phone or MR unit. Might be a bit easier to setup as well.
