Pinkertonk
Jul 22, 2022Aspirant
Nighthawk M6 Pro, what Mesh routers are compatible?
 I have a Nighthawk M6 Pro hotspot.  Last week I tried to connect my NetGear Nighthawk Mesh system only to find it was not compatible.  I ordered from Amazon the Netgear Orbi AC1200 system with the RB...
- Jan 06, 2023For using ethernet port on M6 when connecting a Mesh system to it, you need to enable the ethernet port first. By default, it is disabled. You can set the Power mode from Balanced to Performance mode to enable ethernet port. Thanks
Pinkertonk
Jul 23, 2022Aspirant
Michael, I appreciate your response. Regarding the Nighthawk Mesh system, I posted this thread
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Trying-to-connect-Nighthawk-Mesh-MR60-to-Nighthawk-hotspot/td-p/2239189 and was told it was not compatible. This is why I ordered the Orbi setup.
The nighthawk is the MR6400.
I followed the automatic setup instructions in the app several times. The Orbi is connected to the hotspot MR6400 via a ethernet cable and plugged into the internet port on the Orbi. As soon as the app turns off the hotspot wifi, it is not sending internet to the Orbi. I can connect but it says no internet.
I don't know what AP mode is but I'll look into it.
michaelkenward
Jul 24, 2022Guru - Experienced User
I see that FURRYe38 made the same suggestion in the answer that you linked to. (You could have a saved time by providing a more detailed account of what you have posted before.)
AP mode is designed to avoid problems that can arise when you have two routers on a network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
A lot of people use an Orbi system in AP mode, especially if they have another router in front of it.
The MR6400 is a router. Pile on an Orbi and you can hit the "Double NAT" problem.
Another option would be to work out how to make the MR6400 modem only. Unfortunately, Netgear doesn't seem to provide detailed instructions that I can find for configuring your device in that way. It may not even be possible. Hence the AP suggestion.
Now that two people have suggested AP mode in two separate discussions, perhaps the time is right for you to investigate the idea before you start yet another conversation here.
