Thomtenh10
Jan 13, 2023Aspirant
Nighthawk M6 Pro
Hello, I would like to establish Internet access via the M6 for my existing WLAN with the mesh routers. The M6 should have switched off the WLAN and no DHCP server should run there. The mobile acces...
- Jan 17, 2023
Hi Thomtenh10
Welcome to NETGEAR Community!
Kindly access M6 Web UI, go to Settings > Advanced > Mobile Router Setup
set IP Passthrough to 'ON'
checked Ethernet 'Enabled'Then connect an Ethernet cable to the M6 and to your existing router.
Blanca
Community Team
Blanca_O
Jan 17, 2023NETGEAR Employee Retired
Hi Thomtenh10
Blanca
Community Team
Thomtenh10
Jan 17, 2023Aspirant
Thank you.
