jcarthy
Mar 25, 2023Aspirant
Nighthawk M6 Pro
I am using my M6 pro to connect to my wired network within the network there are two Netgear switches. When I carry out a speed test using the WiFi the speed is faster than the wired connection. s...
Mar 26, 2023Guru - Experienced User
so you're using the M6 to supply your switches? or you're using offloading so the M6 can use the network as internet?
Unsure of exactly what you're doing.
did you test the speed directly connected to the M6 without going through the switches.
