andyjam
Feb 27, 2023Follower
Nighthawk M6 Verizon compatible?
I'm really interested in the new Nighthawk M6 hotspots but Verizon is my cell carrier. Does anyone know if these routers are compatible with the Verizon network and, if so, how complicated it can be t...
JohnPeng
Dec 06, 2023NETGEAR Expert
andyjam wrote:
I'm really interested in the new Nighthawk M6 hotspots but Verizon is my cell carrier. Does anyone know if these routers are compatible with the Verizon network and, if so, how complicated it can be to set up? I've done a lot of digging around online and have found really mixed results. Any help would be much appreciated!
We recently received Verizon TA for MR6500-100PAS and MR6150-100NAS. Right now, you can purchase Verizon SIM cards from their store when you provide the device's IMEI.
But there is a tricky thing that needs handling first. Since MR6150 and MR6550 on the market were loaded with the older FW before Verizon TA. In order for the device to fully computable with Verizon network, please make sure to upgrade the device to the latest releases.
FW: 12.01.47.00
PRI: 04.11
Thanks
rkj001
Feb 17, 2024Aspirant
Is there any chance that Verizon will allow the MR6550 to be used with their prepaid plans anytime soon? It currently appears Verizon only allows it to be used with postpaid plans.
- Blanca_OFeb 22, 2024NETGEAR Employee Retired
Hi rkj001
Pre-paid plans will be available soon. This is still being worked on by Verizon Team. We will provide update once new information will be available.
Blanca
Community Team- vincentpolisiMar 08, 2024Aspirant
I have the Netgear Nighthawk M6 Pro and I initially set it up on the Verizon Prepaid Plan in December 2023 and they ended up converting it to a postpaid plan on my business account.
So, it works with Verizon on both prepaid and postpaid plans.
Verizon has the 5G Ultra wideband mmwave spectrum.
This is a fantastic device.- JohnPengMar 08, 2024NETGEAR Expert
Hi Vincent,Thanks for the positive feedback. I think the reason that your plan is working is because it is not a brand new SIM card.
We know we still have some issues with Verizon Pre-Paid plans, which means that if you enter MR6550 IMEI to Verizon Pre-Paid portal, there is no available plans for the device.
Thanks
John
