zallsup
Jun 28, 2022Tutor
Nighthawk M6 WiFi Hotspot connected to my security cameras
I have trying to use my M6 to connect 2 Vtech security camera and attempt to view these camera remotely via a mobile app. I can view the cameras just fine when all devices are connected to the same ...
- Jun 29, 2022
Apparently Port Forwarding is not an option on the M6110... which is a Wifi hotspot type router. I do have another question that would like some input on, can I connect a router that has port forwarding and then connect the M6110 as the internet provider to the network and then use the other router to connect to the cameras via wifi?
zallsup
Jun 29, 2022Tutor
zallsup
Jun 30, 2022Tutor
So apparently the M6 was not the problem all along. The problem was in the mobile application it appears. removed the app from the phone and reinstalled it. connected the cameras to the Netgear M6 WiFi and then is started working.
