Torodo
Feb 26, 2024Aspirant
Nighthawk M6 will allocate IP address on Guest network but not on regualr 5GHz Wifi network
I had a Nighthawk M2 that died and so purchased a Nighthawk M6 to replace it. Upgraded it to the latest software and firmware versions. Configured to be 5GHz only WPA2 security iPad and iPhones x2...
michaelkenward
Feb 26, 2024Guru - Experienced User
Torodo wrote:
Connected back to the regular Wifi - but the router would still not allocate the PC an IP address
Why will the router allocate the PC an IP address on the guest network but not the regular network???
I haven't seen these exact symptoms before, but a regular issue in Windows is the public/private setting.
Windows likes to protect us from new networks that might be evil. In reality, it often shuts us out of safe networks.
One thought is that you could tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
No harm in checking this.
Torodo
Feb 27, 2024Aspirant
Thanks for the suggestion but no it made no difference whether Windows 10 classified it as a Private or Public network - the Nighthawk M6 will not allocate it an IP address unless the PC connects to the Guest Wifi.
