PedronMax's avatar
PedronMax
Follower
Aug 11, 2024
Nighthawk M6 Will not boot past NETGEAR Screen
Problem occurs when unit being on power for a period with battery removed then when I need unit to be portable and reinstall battery unit won't reboot the NETGEAR or 5G screen
 so I removed the SIM card, and I physically factory reset the device (pushed paperclip end into "reset" hole; held for 10 seconds to allow to reboot). When device rebooted, the "NETGEAR" logo screen came on, and stayed on.
No RepliesBe the first to reply
