simgamer14
Dec 13, 2022Aspirant
Nighthawk m6
I took my battery out so I could enable best range and performance option (it loses signal totally in my bedroom down the hall from the nighthawk. [my older model at&t home base was better]). Is the ...
simgamer14
SKU
6238D
F/W Ver
NTGX65 10.01.47.00
Please let me know if my battery will be ok stored and if there’s anything I can do to help with range and my connection dropping. Internet drops from the nighthawk and often the connection is lost on my devices too. I can’t have this as I run a business, yet this is what AT&T recommended over the Homebase I had that worked fine.
6238D
F/W Ver
NTGX65 10.01.47.00
JohnPeng
Dec 14, 2022NETGEAR Expert
For the data disconnection issue, we had released a maintenance release and AT&T is pushing the update to the devices. You can do a manual upgrade check to have your device upgraded. It will help to improve the data connection stability.
You can store the battery. But it is better to charge it once a while to prevent the power is drained completely.
Thanks
