Skipp63
Apr 19, 2024Follower
Nighthawk M6
I would like to use this router on my sailing yacht. I have also bought an additional antenna. Is it possible to connect a W-LAN router to the Nighthawk M6 to amplify the transmitted signal? Ich möc...
JohnPeng
Apr 24, 2024NETGEAR Expert
Yes. This is quite typical setup with the mobile router. You can connect the WiFi router WAN port to M6's ethernet port.
Thanks
