jacobeligoodson
Dec 04, 2024Follower
Nighthawk m6500 2.5gb ethernet connection
Forum Viewers, When searching the web portal page the option was discoveted to enable ethernet. Once selected the option to select ethernet speed is enabled. The issue is that there is only 10baset...
Dec 05, 2024Guru - Experienced User
do you have a 2.5 gig device connected?
