Kondyba
Jun 17, 2026Aspirant
Nighthawk M7 Pro – How to install a third-party eSIM using a QR code?
Hello, I own a NETGEAR Nighthawk M7 Pro purchased from Amazon Germany. The device is running the latest available firmware, and I am using the latest version of the NETGEAR App. The router is regis...
Adroh
Jul 29, 2026Aspirant
In my oppinion, M7Pro don't support E-Sim. If you want work with E-Sim, you should buy M7.
- FortraJul 29, 2026Luminary
@ Adroh,
I think you have misunderstood the above post. I already know about that, the above user kondyba has a mobile router MH7150 device which is aka (M7 Pro) which does have eSIM support. :D
Correction to my post above I meant M7 portable.
