nick28's avatar
nick28
Nighthawk M7 Pro only connecting via Ethernet and not wifi.
I've been searching tirelessly as to why this is happening. My coworker has the exact same Panasonic laptop and Netgear router, and he is able to connect wirelessly, yet I am not able to connect wirelessly. Same plan, same everything. There has to be a setting that I am not aware of.
Any ideas?
1 Reply
  • by not being able to connect wirelessly, what do you exactly mean by this? do you even see the M7 SSID on the other device? what client device is this? what gen of wifi radio does it have? are the auth protocols match (WPA2 vs WPA3). what radio were you trying to connect to 2.4 5 6 6e or 7?
