oscartiong
Apr 20, 2025Aspirant
Nighthawk M7 Ultra unable to power off when in plugged in mode (without battery)
When battery is in the device, long press power button show a menu with shut down option. However, when using the device in plugged in mode (without battery), long press power button only show rest...
rcpax
Apr 20, 2025Luminary
I have an MR6550.. It behaves the same way you described when there is no battery. I will have to say, this is by design.
oscartiong
Mine is MR7500. It is a shame. I always have to unplug to power off, not sure if it damages the device in long term.
- JBishApr 21, 2025Aspirant
That's by design... Not a glitch or problem persay... Been that way since M5 (First device I started using)
