WarPig-2011
Nov 02, 2017Aspirant
Nighthawk Mobile Hotspot... can it do this?
HI Folks! I'm contemplating purchasing one (or more) of these routers, but before I do, I need to know if I can do the following: I want to set the router up so it will be passive until there...
WarPig-2011
Nov 08, 2017Aspirant
Hmmm. Guess it can't.
MicW
Nov 08, 2017Luminary
HI Warpig
The M1 has a data offload where it will use another modem you may have for internet .It can connect to that other modem via ethernet or wifi. I haven't personally used this feature so I'm not sure if it will automatically switch to cellular if the other system fails
