Albauk
Sep 07, 2020Follower
Nighthawk mobile m2 router
I have just bought a night hawk router mobile m2100. I am using an EEsim card. download speeds vary between 12 and 28 mbps upload speeds vary between 1 and 8 mbps stability is 25%-75% what...
Blanca_O
Nov 22, 2020NETGEAR Employee Retired
Hi Albauk,
Welcome to NETGEAR Community!
Data transfer speed depends on signal strength and interfering radio sources like electrical generators or other mobile router WiFi devices. Review the following possibilities:
• Check your signal strength and network type (for example, LTE 4G is generally faster than 3G).
• Check WiFi interference by powering the mobile router off and on to find a better WiFi channel.
• Switch WiFi channel from 2.4 GHz to 5 GHz.
• If the network signal is low, consider using external antennas or cradle the mobile router with built-in high-gain antennas.
Blanca
Community Team
