Papan
Jan 11, 2023Aspirant
Nighthawk mobile router MR2100 only works with battery removed
I've had my router for a couple of years but it is well looked after and only used lightly. It hasn't ever been dropped or subjected to any moisture or dirt ingress. Just this morning I came to u...
Blanca_O
Jan 18, 2023NETGEAR Employee Retired
Hi Papan
Welcome to NETGEAR Community!
May we please know the device SKU (MR2100-xxx)? This can be checked on the box of the product or on the barcode label
When you try to charge the device, what shows in the LCD UI?
Kindly access MR2100 settings page and check TETHERING section.
Go to Setup > Router Setup > Tethering > select Charge only
Blanca
Community Team
