Rich1e
May 20, 2026Aspirant
Nighthawk mobile router roaming
I have a nighthawk M1 mobile router which I’ve using without problems in my home country (UK). However I am currently in France on holiday with on overseas data plan from EE and the router when swit...
mery56lores
May 28, 2026Aspirant
Hello, Rich1e
The "Roaming Data Disabled" error occurs because data roaming is turned off by default in your router's firmware, and you must bypass the glitchy Netgear app to fix it. Connect your phone or laptop directly to the Nighthawk's Wi-Fi, open a web browser, and type
- Rich1eMay 29, 2026Aspirant
Hi mery56lores, thanks for the tip but pikepass.com just takes you to another netgear sign in page which also doesn’t accept the sign in
- FortraMay 29, 2026Luminary
Let me be clear so that there is no misunderstanding. That site pikepass isn't compatible with your roaming issue in Europe because is for United States users only!
You should get in touch with EE Customer Services.
Hi Fortra, thanks for explaining the poke pass situation - I get the message very clearly but I’ve already been in touch with EE and they assure me that the data sim associated is roaming activated so I don’t think it’s a network issue. The nighthawk M1 was bought independently and I then bought the data sim separately.
