Rich1e
May 20, 2026Aspirant
Nighthawk mobile router roaming
I have a nighthawk M1 mobile router which I’ve using without problems in my home country (UK). However I am currently in France on holiday with on overseas data plan from EE and the router when swit...
Fortra
May 28, 2026Luminary
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone.
Fortra
May 29, 2026Luminary
Copy and paste this link into your address bar of your browser if your using a pc. -> https://ee.co.uk/help/mobile/roaming/pay-as-you-go-charges-for-roaming-in-the-eu
- Rich1eMay 29, 2026Aspirant
Hi Fortra, I didn’t buy the Nighthawk from EE with a data package combined. I bought the nighthawk separately then I bought a data sim from EE. I have indeed been in touch with EE and they confirm that the SIM card is fully roaming enabled.
so I believe the issue is with the nighthawk unit itself
- FortraMay 29, 2026Luminary
Had you registered the NightHawk M1 router, when you installed the NetGear mobile App onto mobile phone while both devices (M1 & Mobile phone) is connected via the same wifi network ?
I can’t remember to be honest but I would assume so. It has worked perfectly in the UK for 2 years.
