Alchemeister
Jan 22, 2020Follower
Nighthawk MR 1100 questions before i buy
Okay Ill try to keep this succint. I havent yet purchased the Nighthawk but i am looking at it as a viable solution. I live rurally and currently use my phone connection as the internet, i have a cel...
JohnPeng
Jan 22, 2020NETGEAR Expert
Could you please advise which carrier is availble at your area and what is the signal level you can get?
Furthermore, do you know what LTE bands can be seen at your area?
If you can have a decent network coverage, MIMO will help to improve the device's performance.
I am not sure what you mean by using the device as signal amplifier. If you have a good coverage, I think you can use the device directly to serve your needs.
Thanks
