chart69
Apr 07, 2021Tutor
Nighthawk MR 2100 Manual Firmware Update
Hi Does anyone know where I can get hold of a copy of firmware for a Nighthawk M2 (MR2100)? My unit seems to have a corrupted firmware version, In the web interface it is displaying unit as A...
Blanca_O
Apr 08, 2021NETGEAR Employee Retired
Hi chart69
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR2100-100EUS)? This can be checked on the box of the product or on the barcode label.
When you try to update the firmware, please make sure that the device is powered on with the battery and not just the power adapter.
Blanca
Community Team
chart69
Apr 08, 2021Tutor
Hi
It is a MR2100-1TLAUS
Devuce is powered on with battery installed and plugged into power as well.
- Blanca_OApr 19, 2021NETGEAR Employee Retired
Hi chart69,
MR2100-1TLAUS is a Telstra SKU unit. Did you purchase this unit from Telstra? There is no option to manually update the firmware as it is locked by the Internet Provider.
Have you tried factory resetting?
Blanca
Community Team- chart69Apr 19, 2021Tutor
Hi Bianca
Yes the unit was purchased from Telstra.
I can go in through tghe web interface (but I have to connect by USB or Ethernet as the wi-fi is disabled) and I can go firmware update and have the option to be able to push a file.
If I do a factory reset (which I had tried previously) I still get the same description for the device (AC81xS) and nothing changed with regards to the diabled wi-fi
I also lose the internet settings totally and I have to manully re-enter these back into the device to get internet access.
- TransfluxorApr 20, 2021Apprentice
If you update to a new Australian one, then the possibility of manual updating will be lost. I have updated several times 1TLAUS since the purchase but did not notice any improvements, now I regret that I updated. I would upgrade to the European version, which still has the option of manual update and would never flash the s_hitty Australian version again. It's too late for me, but you can avoid this mistake.
