pvcon13
Oct 30, 2020Guide
Nighthawk MR 5200 (how to failover to)
The NightHawk MR5200 has a single ethernet port that can used to supply LTE or 5G data to a wired network with Other routers. Specs say is LTE CAT 22, LTE Advanced, 4x4 MIMO, 256QAM with two external antenna as well and does carrier aggregation of the sim carrier inserted.
I have Fios and want to use an external (MIMO 2x2) on roof gain antenna aimed at closest cell tower and would like to failover to this device. Sim for carrier is preselected for a certain amount of data per month and on a normal month the amount of data actually used will be zero so under that data limit. So the goal was to only turn on the 5G or LTE data service during a failure of FIOS.
1) does the ethernet port in this device (NightHawk MR5200) have the option to sense that there is no wired WAN coming in and turn on or turn off the LTE appropriately?
2) if not , would this work with the MR5200 plugged into a second port set to be the failover port of a new dual wan router?
3) If (1) is correct, how do you do this and where can I get a detailed technical manual that has that procedure?
4) if (2) is correct, then what model (of a dual wan router) has anyone used or would suggest using to make this work at speed.
5) If (2) is correct, can I assume that as long as the dual wan router has not failed over to the MR5200 (the night hawk) that NO data on plan is being used?
6) if (2) is correct then the dual wan router received on port 1 the FIOS ONT output and the Lan out goes into the FIOS Router?
7) if (1) is correct, where does the MR 5200 ethernet plug into? The Lan side of the Fios Router?
This is an actual installation, and this product sounds like the right solution, but its hard to find any data on how to do this correctly. It is for a tiny business so when these storms hit again I do not lose contact with my clients and thus my livelyhood. Not kidding. Any guidance on any one question is very much appreciated. Thanks :)
- pvcon13Guide
So no one has done any sort of LTE failover with any model of a Nighthawk?
Or is it that no one has used or knows about the MR5200?
Why does Netgear not provide this info or a means to ask about it?
- pvcon13Guide
........from the netgear mr 5200 page: https://www.netgear.com/images/datasheet/mobile/MR5200.pdf
"For always-On WiFi, the Nighthawk M5 Mobile Router can also provide a reliable backup Internet connection over the mobile network. If Fibre, DSL or Cable is interrupted or unavailable, automatically switch from Ethernet to the 5G/4G network and all devices will remain seamlessly connected"
Great! How?
Where do I plug it into? How do I set it up in the menu?
- pvcon13Guide
The Goal is just to sense when FIOS drops out and turn on wired ethernet (GBe) and everything else works as before. If I need another box then fine. If I do not then how?
