Chaparrita1956
May 22, 2021Follower
Nighthawk MR11. Antennas
I bought a set of small antenas from Amazon that i thought would fit and were purported to fit but they don’t - anyone know which ones fit?
1 Reply
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but your question is specific to a devuce that isn't covered in this section, so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
