JoyMartin
Jul 16, 2021Follower
Nighthawk MR1100 - blinking blue light
 The blue power light on the MR1100 mobile router is continuously blinking in a short burst of two blinks.  I searched this site and haven't found a cause or solution.  Today, my connection keeps drop...
- Jul 22, 2021
Hi JoyMartin
Welcome to NETGEAR Community!
Fast blue blink means the mobile router is transferring data.
Please see reference below for the LED indicator pattern means
[page 9] https://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf
As for the disconnection, please make sure that device signal strength is excellent.
Blanca
Community Team
goodrich4bk
Jul 17, 2021Aspirant
I just set mine up, it's working fine, and the blue light blinks twice just as you describe. So I don't think the light indicates the problem.
