Meerschaum23
Mar 15, 2024Aspirant
Nighthawk MR1100 and Helium Indoor Mobile HotSpot
Hi all, I've got an old MR1100 that I used to have a Verizon SIM card installed but have switched to using a Helium Mobile SIM. It worked alright for a couple of days but then the hotspot remain...
schumaku
Mar 16, 2024Guru - Experienced User
Ok, understand new Helium Mobile SIM ... attempting to work it with the Nighthawk MR1100 -OR- a Helium Indoor Mobile HotSpot?
The Netgear device is covered in the more appropriate Cell Service Mobile Hotspot Modems, AirCards, & Mobile Routers section to discuss Cell Service (AC, L, and MR series) mobile hotspot modems, cards, and mobile router products.
- Meerschaum23Mar 16, 2024Aspirant
New Helium Mobile SIM attempting to make it work with in the MR1100 connected to the Helium Hotspot router. I'll go ahead and post this where you suggested. Thanks for pointing me in the right direction.
- schumakuMar 16, 2024Guru - Experienced User
What is the intention to operate both the MR1100 -and- the Helium HotSpot together? Anyway, a moderator can move your thread accordingly, no need to start with a new post.
The MR1100 is my primary internet source since everything else is too expensive in my rural area, the Helium hotspot is meant to extend the range better than some netgear PoEs I was using previously and make a little crypto while we use it. This worked for a few days.
