Meerschaum23
Mar 15, 2024Aspirant
Nighthawk MR1100 and Helium Indoor Mobile HotSpot
Hi all, I've got an old MR1100 that I used to have a Verizon SIM card installed but have switched to using a Helium Mobile SIM. It worked alright for a couple of days but then the hotspot remain...
Meerschaum23
Mar 16, 2024Aspirant
New Helium Mobile SIM attempting to make it work with in the MR1100 connected to the Helium Hotspot router. I'll go ahead and post this where you suggested. Thanks for pointing me in the right direction.
schumaku
Mar 16, 2024Guru - Experienced User
What is the intention to operate both the MR1100 -and- the Helium HotSpot together? Anyway, a moderator can move your thread accordingly, no need to start with a new post.
