Meerschaum23
Mar 15, 2024Aspirant
Nighthawk MR1100 and Helium Indoor Mobile HotSpot
Hi all, I've got an old MR1100 that I used to have a Verizon SIM card installed but have switched to using a Helium Mobile SIM. It worked alright for a couple of days but then the hotspot remain...
Meerschaum23
Mar 16, 2024Aspirant
Rural internet, that's about it. Helium has better signal since they piggyback off of T-Mobile which has great coverage in my area. The Hotspot is primarily used to extend the range of the MR1100 instead of any smart metering.
schumaku
Mar 16, 2024Guru - Experienced User
All these LPN LoRaWAN (indeed some kind of piggy-back on the mobile networks) are not intended for generic Internet volume data access - all pure IoT cloud, anything connecting to it is going over some cloud services. Technically, everything is possible - doubt somehow mobile provider will assign a public IP address anyway.
- Meerschaum23Mar 16, 2024Aspirant
I read somewhere that someone managed to "get" a static IP through the use of a VPN and some other hardware the name of which escapes me. It warrents more research.
