TxToolman's avatar
TxToolman
Nighthawk MR1100 At&T Unlock help without new SIM
I have a Nighthawk Mobile Router MR1100 from AT&T.  I no longer use and have discontinued my service with AT&T.  I need to unlock to Sell but can't figure out how to do so.  I was able to get the unl...
  • ArodiD's avatar
    Jul 13, 2019
    Hi TxToolman ,
    The unlock process requires another ISP SIM to be inserted where the device will then prompt you for the unlock code.  The unlock code does not change and is locked to the device S/N.  There are 2 options:
    1.  Use a SIM from another ISP and perform the unlock
    2.  Sell the device with unlock code printed somewhere
    Please note that some SKU's will require the unlock code again if the device is factory reset .  I am not sure if the AT&T SKU will require unlock code again after a factory reset but to be safe I would go with option 2.
    Arodi
    Community Team
