_Eric_
Aug 14, 2019Aspirant
Nighthawk MR1100 autonomous mode
Hi ! I am interested in buying the MR1100 Nighthawk Mobile Router. Could you please confirm that this Wifi device can be used in autonomous mode ? I mean having a local wifi network without any si...
JSchnee21
Aug 14, 2019Virtuoso
So you want a battery powered wireless access point? So your laptops / mobile internet devices can talk to each other?
You could do something like this -- which is USB 5V powered, and then get a decent sized Lithium Ion Battery (Anker)
Cheaper and better than the MR1100. I've not tried to use my MR1100 without the SIM card installed. Often Wifi clients on these types of Internet sharing devices are isolated from one another. But this may be configurable.
You could likely buy the MR1100 from Best Buy, try it without the SIM card (or a non-activated SIM card) and then return within the 14 days window (check the return policy first). AT&T may have them in store as well.
