Jakek123
Oct 08, 2022Follower
Nighthawk MR1100 Blinking lights and won't charge
So earlier today I plugged my mobile hotspot up to charge. When I came back to it the blue and orange lights were flashing in sequence one after the other and a battery symbol with a clock under it wa...
michaelkenward
Oct 09, 2022Guru - Experienced User
Jakek123 wrote:
So earlier today I plugged my mobile hotspot up to charge. When I came back to it the blue and orange lights were flashing in sequence one after the other and a battery symbol with a clock under it was on the screen. It does this both when I try to charge it or turn it on.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
