QuicksilverZach
Feb 04, 2020Aspirant
Nighthawk MR1100 Disconnecting
I just bought a Nighthawk MR1100 and got a SIM card for it. I was able to follow the instructions and get to the WiFi Manager. The speed is low, 3mbps down and up at the most, and it frequently discon...
Blanca_O
Feb 09, 2020NETGEAR Employee Retired
Welcome to NETGEAR Community!
Please contact the carrier and make sure that you have the correct APN information.
Kindly check as well that the signal strength is excellent. If signal indicator is low, try moving the device to a location with a clear view of the sky.
Blanca
Community Team
