Overtime's avatar
Overtime
Nighthawk MR1100 does not revert IP Passthrough on factory-defaults reset
On the latest firmware with IP Passthrough enabled.  Had an issue that required resetting to factory defaults, and couldn't connect to it.  Used the physical reset button but that was complicated whe...
