DarthKoda
Feb 18, 2019Guide
Nighthawk MR1100 FW NTG9X50C_10.20.05.02 Wont Update
No matter what I do. I can't get my router to do a Firmware update. It's driving me crazy. I have to manually power off then on the router every 24 hrs. Why? Because after 24hrs, the router stops wor...
DarthKoda
Feb 19, 2019Guide
Just a update.
I have tried the 192.168.1.1 aka attwifimanager, I have also tried factory resetting thru attwifimanager, and a hard factory reset by holding the Reset button by the battery. No Joy.
Called ATT and was told it was a NetGear issue. Was transfered to NetGear and was told it was a ATT issue. Both tried several things with me. But, it was clear I had already tried them all.
So, if you do happen upon a ATT branded M1 MR1100 NightHawk Mobile Router with Firmware NTG9X50C_10.20.05.02 and it will not update out of the box or in the first few days of ownership. Send it back from hence it came. It's not worth the headache.
Overall, it's a great little router. Just my model has a serious FW update issue.
I am not giving up on my little Nighthawk. Maybe one day when the Planets align, the stars are in the right order, and a super moon come into alignment. My router will update it's firmware. :)
