DarthKoda
Feb 18, 2019Guide
Nighthawk MR1100 FW NTG9X50C_10.20.05.02 Wont Update
No matter what I do. I can't get my router to do a Firmware update. It's driving me crazy. I have to manually power off then on the router every 24 hrs. Why? Because after 24hrs, the router stops wor...
Blanca_O
Feb 21, 2019NETGEAR Employee Retired
Hi DarthKoda
What is the error message when you try to update the firmware?
May we please have the exact model # of the device?
Blanca
Community Team
kskenyon
Mar 08, 2019Tutor
Any update on this firmware update problem?
- DarthKodaMar 08, 2019Guide
Everyday I log onto the router and do a check for updates. Everyday, it tells me my firmware is up to date.
So nothing new. Still on 10.20.05.02
- FCB90Apr 09, 2019StarSame problem with 2gen - MR1100-2A1NAS.
Netgear is a joke in terms of Network devices. Again.- Scottd9000Apr 30, 2019Tutor
Same here but I am on 12.02.06.01 and it won't update. Reset, Reboot, Reboot, Reboot etc. Keep checking but says it's up to date.
