DarthKoda
Feb 18, 2019Guide
Nighthawk MR1100 FW NTG9X50C_10.20.05.02 Wont Update
No matter what I do. I can't get my router to do a Firmware update. It's driving me crazy. I have to manually power off then on the router every 24 hrs. Why? Because after 24hrs, the router stops wor...
ngtrandiep
Oct 19, 2019Aspirant
Any news on this update issue? My router gets same problem. I figured out all of other M1 routers which are not distributed by AT&T have the option that allow user update firmware by uploading file. I don't see this option in AT&T M1. Meanwhile, the FOTA is useless, it keeps showing "Current software is up to date."
