DarthKoda
Feb 18, 2019Guide
Nighthawk MR1100 FW NTG9X50C_10.20.05.02 Wont Update
No matter what I do. I can't get my router to do a Firmware update. It's driving me crazy. I have to manually power off then on the router every 24 hrs. Why? Because after 24hrs, the router stops wor...
Mrblazed
Oct 20, 2019Star
- hollnagelcMar 13, 2020AspirantI have this same firmware and can’t get it to update either. I’ve had AT&T attempt to push me an update 3 times.
It will show Downloading 0% then it just says download error. Then goes back to showing it’s up to date. Until I ask them to push an update to me again.- JohnPengMar 14, 2020NETGEAR Expert
I will check for the upgrade issue on MR1100-1A1NAS SKU and get back to you.
Thanks
- hollnagelcMar 14, 2020Aspirant
Thanks JohnPeng that would be great!
