DarthKoda
Feb 18, 2019Guide
Nighthawk MR1100 FW NTG9X50C_10.20.05.02 Wont Update
No matter what I do. I can't get my router to do a Firmware update. It's driving me crazy. I have to manually power off then on the router every 24 hrs. Why? Because after 24hrs, the router stops wor...
hollnagelc
Mar 13, 2020Aspirant
I have this same firmware and can’t get it to update either. I’ve had AT&T attempt to push me an update 3 times.
It will show Downloading 0% then it just says download error. Then goes back to showing it’s up to date. Until I ask them to push an update to me again.
JohnPeng
Mar 14, 2020NETGEAR Expert
I will check for the upgrade issue on MR1100-1A1NAS SKU and get back to you.
Thanks
- hollnagelcMar 14, 2020Aspirant
Thanks JohnPeng that would be great!
- FCB90Mar 15, 2020Starhollnagelc don't be naive - they've been trying for a year or more and they never have done anything to help. Support does not exist in this case.
- hollnagelcMar 15, 2020AspirantAh I gotcha. I didn’t realize it had been an ongoing thing. Thought maybe my device was just having issues.
