eodbob
Dec 21, 2019Tutor
Nighthawk MR1100 I would like to get more bars on my router.
I am getting two bars on my router but I live in a rural area and I need to know if there is something available to help me get a better signal.
Blanca_O
Feb 12, 2020NETGEAR Employee Retired
Hi eodbob,
If the signal strength LED show only few bars, the mobile router's reception is poor. Try moving it to a location with a clear view of the sky (for example, near a window). If the reception does not improve, consider purchasing an external antenna
Blanca
Community Team
